1 - 20 of 28 Posts
Please vist http://passatb5.wikidot.com/ for the most up-to-Date write ups
VAG-COM Locators:
http://www.steve-hall.com/cgi-bin/VAG-Locator.pl
http://www.frappr.com/vagcomlocator
Parts
1.8t
V6
  • url=http://www.passatworld.com/forums/showthread.php?t=191705]V6 PCV system replacement (with pics)[/url]-ashman78
  • url=http://www.passatworld.com/forums/showthread.php?t=167289]V6 Coolant Temperature Sensor replacement writeup[/url] -ctobio
  • url=http://www.passatworld.com/forums/showthread.php?t=143153]V6 coolant sensor replacement with pic's[/url] -crash893
  • url=http://www.passatworld.com/forums/showthread.php?t=150816]Sparkplug change[/url]-crash893 pics
  • url=http://www.superchargedaudi.com/howto/tbwriteup.html]v6 Timeingbelt writeup[/url]-Walter Freitag
  • list of mods for v6-many
General Engine
  • Fuel Trim Information wolfsburg_de
  • FPR – Fuel Pressure Regulator Primer –Rusty
  • url=http://www.passatworld.com/forums/showthread.php?t=136788]Fuel Filter Replacement How2[/url] –PassatVariantPunk
  • url=http://www.passatworld.com/forums/showthread.php?t=108636]Fuel Filter Removal/Replacement - 1.8T[/url] -Scuba2001
  • url=http://www.passatworld.com/forums/showthread.php?t=104388]APR Snub Mount Installation[/url] -HermanH
  • All About ECU Upgrades (CHIPS!) -The GREEK
  • url=http://www.passatworld.com/forums/showthread.php?t=133976]Trouble Shooting your ICM[/url] wchp
  • url=http://www.passatworld.com/forums/showthread.php?t=124928]MAFS cleaning (multiple pictures)[/url] -w100
  • Part I of Very good write up on vacuum engine diagnostic
  • Part II of Very good vacuum engine diagnostic – Nenad
  • url=http://www.passatworld.com/forums/showthread.php?t=156842]Oil Change How To[/url] –Boris
  • NEW OIL GUIDELINES FOR 1.8T -someone
  • url=http://www.passatworld.com/forums/showthread.php?t=154943]Vacuum Leak - Broken L Hose[/url] -warknj
  • url=http://www.passatworld.com/forums/showthread.php?t=147520]Vacuum Line Replacement on ATW[/url] -tregate
Drivetrain
  • url=http://www.passatworld.com/forums/showthread.php?t=159027]How To - '98 Passat 1.8T/V6 Axle Replacement[/url] -Scuba2001
  • url=http://www.passatworld.com/forums/showthread.php?t=154685]Differential fluid change for Tiptronic.[/url] –PZ
  • url=http://www.passatworld.com/forums/showthread.php?t=118567]Tiptronic Performance Mods[/url] -OakHillVariant
  • url=http://www.passatworld.com/forums/showthread.php?t=104947]Transmission Fluid Change[/url] swett
  • url=http://www.taligentx.com/passat/maintenance/cvjoints/]CV joint replacement[/url]-taligentx.com
  • url=http://www.taligentx.com/passat/maintenance/atfchange/]ATF /filter change [/url]-taligentx.com
  • ATF Pressure adjust mod -tdiclub.com
  • url=http://www.passatworld.com/forums/showthread.php?t=174429]$10 DIY Tiptronic Fluid Tool[/url]-crew217
Suspension
Brakes / ABS
Tires/Wheels
Manuals -1.8T by abamoura
Exterior lighting
Body
Interior
Troubleshooting
Electrical
A\V CLUB
Warranty info
Other
DEALER RATINGS
  • url=http://1.8t.org/dealers/]dealer ratings[/url]-1.8t.org
Created 1/20/05
Last updated -10/26/05 -144 witeups
I can update it if need be
but it would be best if i got a pm saying "hey i found this write up" or " you forgot this write up"
also does anyone know where could host some file beucase i got a few write ups squrilled away that still have the pictures intact
i would love to put them up but i dont have any hosting capablity
None of these links worked for me..
* AEB/ATW Engine Manual
* V6 Engine Manual I think this is for Jettas and Golfs only
* Manual Transmission Overhaul
* Auto transmission Overhaul
* Sunroof Manual
* Electric Wiring
* Sunroof Manual
* Electric Wiring
Did anyone save these PDF files to their computers? I will host them if they need to be hosted. I could really use the AEB/ATW manual.
Please vist <A href="http://passatb5.wikidot.com/" target=_blank>http://passatb5.wikidot.com/</A> for the most up-to-Date write ups
VAG-COM Locators:
<A href="http://www.steve-hall.com/cgi-bin/VAG-Locator.pl" target=_blank>http://www.steve-hall.com/cgi-bin/VAG-Locator.pl</A>
<A href="http://www.frappr.com/vagcomlocator" target=_blank>http://www.frappr.com/vagcomlocator</A>
Parts
  • <A href="http://www.passatworld.com/forums/showthread.php?t=175057" target=_blank>Parts Sources</A>-Crew217
  • <A href="http://www.passatworld.com/forums/showthread.php?t=185552" target=_blank>Some PR#, can be interesting..</A>-Nenad
1.8t
  • <A href="http://www.passatworld.com/forums/showthread.php?t=239316" target=_blank>ICM Maintenance Idea - AEB's only</A>-jjs1978
  • <A href="http://www.passatworld.com/forums/showthread.php?t=161749" target=_blank>FMIC Install - DIY $500</A>-Rusty
  • <A href="http://www.passatworld.com/forums/showthread.php?t=171235" target=_blank>DIY write up: PCV valves, 1.8t</A>- Spirare
  • <A href="http://www.passatworld.com/forums/showthread.php?t=138611" target=_blank>2 oil leaks found/fixed, clogged/cracked PCV valves (pics)</A> -vwfool2000
  • <A href="http://www.passatworld.com/forums/showthread.php?t=169321" target=_blank>Simple pre-cat oxygen sensor how-to, A.K.A. heated 02 sensor</A> -Colin
  • <A href="http://www.passatworld.com/forums/showthread.php?t=167704" target=_blank>1.8T Timing Belt Replacement - Revised</A> -DaddyMatt
  • <A href="http://www.passatworld.com/forums/showthread.php?t=166611" target=_blank>1.8T Waterpump/Thermostat Replacement</A> -B5V6
  • <A href="http://www.passatworld.com/forums/showthread.php?t=161804" target=_blank>How-To: Oil Catch Can Installation</A> -Scuba2001
  • <A href="http://www.passatworld.com/forums/showthread.php?t=158954" target=_blank>DIY: Intake Manifold Gasket</A> -98PassatPimpin
  • <A href="http://www.passatworld.com/forums/showthread.php?t=156553" target=_blank>SMOC – Side Mount Oil Cooler - Install</A> –Rusty
  • <A href="http://www.passatworld.com/forums/showthread.php?t=135474" target=_blank>Motor Mount Install WriteUp - incld Front Snub</A> -Scuba2001
  • <A href="http://www.passatworld.com/forums/showthread.php?t=126946" target=_blank>K03 Sport</A> ONE8T
  • <A href="http://www.passatworld.com/forums/showthread.php?t=121852" target=_blank>K04 Upgrade/Installation</A> -HermanH
  • <A href="http://www.passatworld.com/forums/showthread.php?t=108139" target=_blank>Engine Data</A> -Rich P
  • <A href="http://www.passatworld.com/forums/showthread.php?t=104389" target=_blank>Jetex Exhaust System for 1.8T Passat</A> HermanH
  • <A href="http://www.passatworld.com/forums/showthread.php?t=102284" target=_blank>Coil Pack Problems & the 1.8T Engine (B5.5's)</A> MN Snowman
  • <A href="http://www.passatworld.com/forums/showthread.php?t=90288&highlight=COAM" target=_blank>COAM Modification</A> - Boris
  • <A href="http://www.taligentx.com/passat/maintenance/timingbelt/" target=_blank>timeing belt replacement</A> -taligentx.com
  • <A href="http://www.taligentx.com/passat/maintenance/valvecovergasket/" target=_blank>Valve cover gasket</A> -taligentx.com
  • <A href="http://www.taligentx.com/passat/maintenance/throttlebody/" target=_blank>Throttlebody cleaning</A> -taligentx.com
  • <A href="http://www.taligentx.com/passat/maintenance/coolanttempsender/" target=_blank>Coolant temp sender replace</A> -taligentx.com
  • <A href="http://www.passatworld.com/forums/showthread.php?t=175760" target=_blank>N75 UPGRADE CAUTIONS - Read Before Purchase</A>-Rusty
V6
  • <A href="http://www.passatworld.com/forums/showthread.php?t=119944" target=_blank>list of mods for v6</A>-many
General Engine
  • <A href="http://www.passatworld.com/forums/showthread.php?t=115267" target=_blank>Fuel Trim Information</A> wolfsburg_de
  • <A href="http://www.passatworld.com/forums/showthread.php?t=130393" target=_blank>FPR – Fuel Pressure Regulator Primer</A> –Rusty
  • <A href="http://www.passatworld.com/forums/showthread.php?t=102329" target=_blank>All About ECU Upgrades (CHIPS!)</A> -The GREEK
  • <A href="http://www.passatworld.com/forums/showthread.php?t=170382" target=_blank>Part I of Very good write up on vacuum engine diagnostic</A>
  • <A href="http://www.passatworld.com/forums/showthread.php?t=170383" target=_blank>Part II of Very good vacuum engine diagnostic</A> – Nenad
  • <A href="http://www.vw.com/vwcom/content/objects/pdf/service_maint/oilchart.pdf" target=_blank>NEW OIL GUIDELINES FOR 1.8T</A> -someone
Drivetrain
  • <A href="http://forums.tdiclub.com/showflat.php?Cat=0&Number=583532&page=&fpart=1&vc=1" target=_blank>ATF Pressure adjust mod</A> -tdiclub.com
Suspension
  • <A href="http://www.passatworld.com/forums/showthread.php?t=150201" target=_blank>Tie Rod End Replacement</A> -coloradob5
  • <A href="http://www.passatworld.com/forums/showthread.php?t=122154" target=_blank>Suspension Basics from Edmunds.com (Submitted by dac2800)</A> BF
  • <A href="http://www.passatworld.com/forums/showthread.php?t=104287" target=_blank>Replacement of suspension on FWD Passats</A> -HermanH
  • <A href="http://www.passatworld.com/forums/showthread.php?t=104284" target=_blank>Neuspeed Rear Anti Roll Bar Installation</A> -HermanH
  • <A href="http://www.passatworld.com/forums/showthread.php?t=103600" target=_blank>Control Arm FAQ</A> -Serratt
  • <A href="http://www.passatworld.com/forums/showthread.php?t=103523" target=_blank>Performance Tire Reviews</A> -passatlover99
  • <A href="http://www.passatworld.com/forums/showthread.php?t=126413&highlight=suspension" target=_blank>Secret Project 1BE</A>-OakHillVariant (poll of diffrent setups)
Brakes / ABS
  • <A href="http://www.passatworld.com/forums/showthread.php?t=155771" target=_blank>STEP BY STEP: REPLACING AN ABS UNIT FOR UNDER $200</A> –DRMUD
  • <A href="http://www.passatworld.com/forums/showthread.php?t=109384" target=_blank>Aftermarket Brake Reviews</A> -passatlover99
  • <A href="http://www.passatworld.com/forums/showthread.php?t=107237" target=_blank>Wet Braking Shield Installation</A> -passatlover99
  • <A href="http://www.akebonobrakes.com/company/media_center/white_papers/akebono_ceramic_tech.pdf" target=_blank>Ceramic break 101</A> -crash893
  • <A href="http://www.passatworld.com/forums/showthread.php?t=142573" target=_blank>Fenderliner vent install</A>-Meltemie
  • <A href="http://www.taligentx.com/passat/maintenance/brakefluid/" target=_blank>Brake & Clutch Fluid Flush</A>-taligentx
  • <A href="http://www.passatworld.com/forums/showthread.php?t=179518" target=_blank>Brake pad and rotor replacement</A>-a4passata6
Tires/Wheels
  • <A href="http://www.passatworld.com/forums/showthread.php?t=176887" target=_blank>Mille Mille ‘Brilliant Silver’ – Finally a Perfect Match</A> - ControlDude
  • <A href="http://1.8t.org/~tabamoura/manual/aeb.atwengine.pdf" target=_blank>AEB/ATW Engine Manual</A>
  • <A href="http://1.8t.org/~tabamoura/manual/aaa_afp_2_8.pdf" target=_blank>V6 Engine Manual</A> I think this is for Jettas and Golfs only
  • <A href="http://1.8t.org/~tabamoura/manual/mt_012_overhaul.pdf" target=_blank>Manual Transmission Overhaul</A>
  • <A href="http://1.8t.org/~tabamoura/manual/at_01V_overhaul.pdf" target=_blank>Auto transmission Overhaul</A>
  • <A href="http://1.8t.org/~tabamoura/manual/roof_98.pdf" target=_blank>Sunroof Manual</A>
  • <A href="http://1.8t.org/~tabamoura/manual/wiring.pdf" target=_blank>Electric Wiring</A>
Exterior lighting
  • <A href="http://www.passatworld.com/forums/showthread.php?t=163183" target=_blank>Instructions for Adding City Light Connection for B5 HIDs</A> -D.Passat00
  • <A href="http://www.passatworld.com/forums/showthread.php?t=163182" target=_blank>Instructions for removing headlight and corner light for B5</A> -D.Passat00
  • <A href="http://www.passatworld.com/forums/showthread.php?t=154423" target=_blank>DIY: Joey Mod on HID LOOK</A> -Stranded In Daytona
  • <A href="http://www.passatworld.com/forums/showthread.php?t=151860" target=_blank>How To - B5 HID/HID-Look Headlight Leveling Motors</A> -Scuba2001
  • <A href="http://www.passatworld.com/forums/showthread.php?t=150378" target=_blank>DIY: Replacing Foglight Bulbs (MY 2001.5-2003)</A>- Rich P
  • <A href="http://www.passatworld.com/forums/showthread.php?t=150377" target=_blank>DIY: Replacing Headlight Bulbs (MY 2001.5-2003, except HIDs)</A> -Rich P
  • <A href="http://www.passatworld.com/forums/showthread.php?t=150374" target=_blank>DIY: Disabling Daytime Running Lights (DRL)</A> -Rich P
  • <A href="http://www.passatworld.com/forums/showthread.php?t=133954" target=_blank>Joey Mod HID Painting Write Up</A> -Scuba2001
  • <A href="http://www.passatworld.com/forums/showthread.php?t=116504" target=_blank>Instructions: Brake Light Mod w/o Integrated Fog Light</A>- AJChenMPH
  • <A href="http://www.passatworld.com/forums/showthread.php?t=116455" target=_blank>Adding OE foglights to a B5.5 GL</A>-Gurft
  • <A href="http://www.passatworld.com/forums/showthread.php?t=111819" target=_blank>Black Headlight Mod</A> -Kosmas
  • <A href="http://www.passatworld.com/forums/showthread.php?t=106495" target=_blank>"Audi Style" Daytime Running Lights</A> Bonthron
Body
  • <A href="http://www.passatworld.com/forums/showthread.php?t=174272" target=_blank>Belly Pan Fastener Parts List</A>-Rusty
  • <A href="http://www.passatworld.com/forums/showthread.php?t=178777" target=_blank>A Simple FAQ About Painted Lowers or Valences</A>-chrisyoon
  • <A href="http://www.passatworld.com/forums/showthread.php?t=151261" target=_blank>Jack Pad Install</A> -Rusty
  • <A href="http://www.passatworld.com/forums/showthread.php?t=150381" target=_blank>DIY: Replacing Side View Mirrors</A> -Rich P
  • <A href="http://www.passatworld.com/forums/showthread.php?t=142573" target=_blank>Fender liner vent install</A> –Meltemie
  • <A href="http://www.passatworld.com/forums/showthread.php?t=141788" target=_blank>B5.5 Front Bumper Removal</A> -Gurft
  • <A href="http://www.passatworld.com/forums/showthread.php?t=135372" target=_blank>replacing windshield washer spray jets</A> –shummer
  • <A href="http://www.passatworld.com/forums/showthread.php?t=127303" target=_blank>Aero Blade Wiper Refill Procedure (With Pics)</A> -vuvision
  • <A href="http://www.passatworld.com/forums/showthread.php?t=102926" target=_blank>Installation of Da'Lan Trailer Hitch</A> -Mr_Mike
  • <A href="http://store.yahoo.com/autopia/inf-pc7424.html" target=_blank>How-to Use The Porter Cable 7424 Polisher</A>-crash893
  • <A href="http://www.taligentx.com/passat/maintenance/doorlockmechanism/" target=_blank>door lock mechanism</A>-taligentx.com
Interior
  • <A href="http://home.comcast.net/~theshums2/TSB/Latch.pdf" target=_blank>LATCH Installation TSB</A>-ckatkinson
  • <A href="http://www.passatworld.com/forums/showthread.php?t=173929" target=_blank>Climate control bulb replacement</A>-peppy
  • <A href="http://www.passatworld.com/forums/showthread.php?t=177981" target=_blank>Dash vent light bulb removal/replacement (1998- early 2003)</A>-SeattleReign
  • <A href="http://www.passatworld.com/forums/showthread.php?t=177478" target=_blank>Neon Lights Write up with PICS!</A>-Oripaamoni
  • <A href="http://www.passatworld.com/forums/showthread.php?t=167723" target=_blank>Airbag Resistor for Aftermarket Seats</A> -Rusty
  • <A href="http://www.passatworld.com/forums/showthread.php?t=151901" target=_blank>DIY: Pulling Out The Light Switch</A>- Rich P
  • <A href="http://www.passatworld.com/forums/showthread.php?t=139569" target=_blank>Illuminated door handles (ambient light)</A> -1.8Tabamoura
  • <A href="http://www.passatworld.com/forums/showthread.php?t=125297" target=_blank>Vent bulb Replacement</A>-MeinPassat
  • <A href="http://www.passatworld.com/forums/showthread.php?t=121579" target=_blank>Removing and CleaningtheB5FrontCup-holder</A>-Bonthron
  • <A href="http://www.passatworld.com/forums/showthread.php?t=116608" target=_blank>Instructions: Installing TipMod</A>-AJChenMPH
  • <A href="http://www.passatworld.com/forums/showthread.php?t=102662" target=_blank>Installation of Alien-Tech remote window controller</A>-atomicalex
  • <A href="http://www.passatworld.com/forums/showthread.php?t=173803" target=_blank>Dash Rattle fix</A>- leadfoot
  • <A href="http://www.passatworld.com/forums/showthread.php?t=173036" target=_blank>Vent Light Mod (for newer Passats)</A>-JimmyDee
w8maplight
  • <A href="http://www.passatworld.com/forums/showthread.php?t=102193" target=_blank>InstallingW8 overhead light panel</A>-jwil
  • <A href="http://www.passatworld.com/forums/showthread.php?t=102368" target=_blank>Installation of sunroof LED mod</A>-Mr_Mike
steeringwheel
  • <A href="http://www.passatworld.com/forums/showthread.php?t=150638" target=_blank>InstallingR32 3spokesteeringwheel(multifunctionswap)</A>–SAVela
  • <A href="http://www.passatworld.com/forums/showthread.php?t=144524" target=_blank>R32Steering WheelRemoval/InstallWriteUp</A>-schmove
EuroSwitch
  • <A href="http://www.passatworld.com/forums/showthread.php?t=150375" target=_blank>FYI: EuroswitchFunctions</A>-RichP
BOOSTGAUGES
  • <A href="http://www.passatworld.com/forums/showthread.php?t=157296" target=_blank>BoostGauge Installed-pics</A>V-MANN
  • <A href="http://www.passatworld.com/forums/showthread.php?t=158910" target=_blank>DIY:Howto installaBoostGauge&A-pillarpod</A>–SausageRocket
  • <A href="http://www.passatworld.com/forums/showthread.php?t=111388" target=_blank>InstallInstructions: IMPConceptsIntegratedBoostGauge</A>-Bonthron
AC
  • <A href="http://www.passatworld.com/forums/showthread.php?t=150166" target=_blank>Air ConditioningEvaporatorReplacement</A>-AidanLee
Troubleshooting
  • <A href="http://www.passatworld.com/forums/showthread.php?t=150634" target=_blank>DTCLookup Table</A>–FastLane
  • <A href="http://www.steve-hall.com/cgi-bin/VAG-Locator.pl" target=_blank>VAG-COM Locator</A>-Pass-variant
Electrical
  • <A href="http://www.passatworld.com/forums/showthread.php?t=127381" target=_blank>Addingfuses toyourfuseboxandrelayplate</A>atomicalex
  • <A href="http://www.passatworld.com/forums/showthread.php?t=125493" target=_blank>Headlight ConnectorPinout&EuroswitchContactInfo</A>-soundguybob
  • <A href="http://www.passatworld.com/forums/showthread.php?t=172812" target=_blank>New way through firewall (powerlines for subs etc.)</A>-dan
A\V CLUB
  • <A href="http://www.bluespot.co.uk/cables.asp" target=_blank>Every possible Blaupunkt Accessory Harness Available</A>-Tom Parish
  • <A href="http://www.passatworld.com/forums/showthread.php?t=168954" target=_blank>2004.5Passat -BlaupunktAmericaInstall-Pics!</A>–HamrWebDesign
  • <A href="http://www.passatworld.com/forums/showthread.php?t=130170" target=_blank>Satellite SiriusRadioInstallationforSingleDin(56K)</A>–chrisyoon
  • <A href="http://www.passatworld.com/forums/showthread.php?t=111088" target=_blank>New-Double DinInstallHow-To</A>-Scuba2001
  • <A href="http://www.passatworld.com/forums/showthread.php?t=102382" target=_blank>Installation ofdoubledin</A>-Scuba2001
  • <A href="http://www.passatworld.com/forums/showthread.php?t=102192" target=_blank>InstallingOE navigation system(MFD)</A>-jwil
Warranty info
  • <A href="http://www.passatworld.com/forums/showthread.php?t=166932" target=_blank>Magnusson-Moss Act</A>-quality_sound
  • <A href="http://www.passatworld.com/forums/showthread.php?t=132192" target=_blank>WarrantyWork, AfterWarrantyRepairs,etc...</A>DrewAment
Other
  • <A href="http://userfs.cec.wustl.edu/~lrr1/vwremote/" target=_blank>Key Battery Replacement</A>-lou
  • <A href="http://www.passatworld.com/forums/showthread.php?t=94696" target=_blank>Switchblade RetrofittingInfo</A>-Scuba2001
  • <A href="http://www.passatworld.com/forums/showthread.php?t=181120" target=_blank>Everything you need to know about buying a 2nd Switchblade Remote</A>-LateAPXR
DEALER RATINGS
Created 1/20/05
Sorry, I do not understand your meaning, I just start to learn it, Could you pls describe it in details?
1 - 20 of 28 Posts
