2
Guest
ENGINE
Type: Hyundai Beta 2.0-liter DOHC 4-cylinder, inline with CVVT (transverse mounted)
Materials: cast iron block/aluminum cylinder head
Displacement: 2.0 liters (1975cc/120.5 cubic inches)
Bore x stroke: 82.0mm x 93.5mm (3.23 inches x 3.68 inches)
Compression ratio: 10.1:1
Horsepower: (estimated) 140 @ 6,000 RPM
Torque: (estimated) 136 lb-ft @ 4,500 RPM
Valves per cylinder: Four
Fuel system: Electronic multi-port fuel injection, in-tank fuel pump
Emission controls: Three-way catalyst
Exhaust: Single
Type: Hyundai Delta DOHC V6(transverse mounted)
Materials: aluminum block/aluminum heads
Displacement: 2.7 liters (2656cc/162 cubic inches)
Bore x stroke: 86.7mm x 75.0mm (3.41 inches x 2.95 inches)
Compression ratio: 10.0:1
Horsepower: (estimated) 173 @ 6,000 RPM
Torque: (estimated) 178 lb-ft. @ 4,000 RPM
Exhaust: Dual
6th Grade
Not nearly as ugly as that other one-this one looks fine except for the pug nose.
Isn't this just an updated Santa Fe with better fenders and front and rear treatments?
2
Guest
Could be, investigate that and get back to me! :p
From the Chicago auto show information link: (linkage)
# New SUV, slightly smaller than Santa Fe.
# 140 hp, 2.0-liter inline four or 2.7-liter, 173 hp V6.
# Available in front wheel- or all-wheel-drive.
# In dealerships this summer.
I like the headlight treatment and angular cuts in the hood, but I agree that nose with all that funky plastic looks kind of odd, like it was an after thought or somone disturbed an otherwise nice front end
