Could i just wire them from the fogs located in the highbeams? or would that cause to much amperage for the circuit or not enough power for both sets?
i would really install a relay, they are really simple to use and add another measure of safety. they allow you to run a seperately fused, full 12 volts to the fogs, then you can use the old fog circuit to turn the relay "on" and it powers the fogs. :thumbup:
thanks ill look into that :) even tho ive never seen a car with fogs in the high beam. they do help out and id like to keep them functional.
use a switch on one of the dead spots you have by the radio.:thumbup:
