1 - 8 of 8 Posts
Wife and I went out to dinner tonight, drove her car. On the way back home, on comes the CEL.
I'm guessing it's related to the car never really heating up between trips. For life of me I can't remember the code it usually gets.
All week long my wife drives her car less than 3 miles to work and back. You know that's not good. Every weekend I try to get on the interstate and drive it hard for at least 20 minutes.
Will scan tomorrow.
Wasn't quite prepared for this.
Address 01: Engine Labels: 078-907-551-ATQ.lbl
Part No: 3B0 907 551 CG
Component: 2.8L V6/5V G 0001
1 Fault Found:
16805 - Warm Up Catalyst; Bank 1
P0421 - 35-10 - Efficiency Below Threshold - Intermittent
Readiness: 0000 0000
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 J
Component: CLIMATRONIC B5GP 0004
Coding: 17200
Shop #: WSC 00028
VCID: 285F02AFC8E2060FCF-5140
5 Faults Found:
00792 - A/C Pressure Switch (F129)
35-00 - -
00603 - Footwell/defroster Flap Positioning Motor (V85)
37-00 - Faulty
01271 - Positioning Motor for Temperature Flap (V68)
37-00 - Faulty
01272 - Positioning Motor for Central Flap (V70)
37-00 - Faulty
01274 - Air Flow Flap Positioning Motor (V71)
37-00 - Faulty
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 C
Component: 09 AIRBAG VW61 04 0001
Coding: 12345
Shop #: WSC 00028
VCID: 2447169FB4CAE26FE3-5124
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 36: Seat Mem. Drvr Labels: 3B1-959-760.lbl
Part No: 3B1 959 760 E
Component: Sitzverstellung 0301
Shop #: WSC 00000 000 00000
VCID: 2F6DE9B3BD0C51370E-5106
3 Faults Found:
01008 - Note; Emergency OFF Switch is Active!
000 - - - Intermittent
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
01010 - Sensor for Driver's Seat Recline (G219)
007 - Short to Ground
End-------------------------(Elapsed Time: 04:45)--------------------------
Discussion Starter #6 (Edited)
I reset the ECU code for the P0421 and I'll see what happens. We've been running errands with her car instead of mine. So far the CEL has stayed off.
Looks like I win the bet. But, with B5 P0421 odds it won’t pay much.
Not so fast there chumly. I gotta call you on a technicality. You said P04xx. :p
Seriously though, good call.
1 - 8 of 8 Posts
