My HU has power because the lights come on. But the screen is black. And when I hook up the factory unit there is no problem. Is it something internal with the HU or my wiring?
2004 B5.5 Variant 1.8T
You're going to need to give us a little more info than that. What harness did you use? What head unit? What mode of Passat?
I have a 2003 Volkswagen passat. Kenwood ddx 374bt head unit. And I've tried the scosche harness and I also have the pac rp4 vw11 harness and neither one works. I think its something internal. But I figured I'd get some other opinions
It should work just fine if you verify you have a good ground, 12v constant on the yellow wire and 12v switched on the red wire. You have a bad head unit.
