1 - 3 of 3 Posts
Hello Passatworld,
How do I unclip the connectors in the accordion cover of the rear doors to clean the connections? Tried just pulling and had no luck.
Thanks,
Miles2Go
Gently pry the locking fingers (small flat-head screwdriver works here) away from the body-side plug, while pulling the door-side plug out. It really is that simple. :)
The end of the clip (locking fingers) on the accordion side is split, if you pull hard enough, it will disconnect from the body side plug. First time though, do as cuppie suggests.
1 - 3 of 3 Posts
