1 - 7 of 7 Posts
Any way to tell the difference?
In the Passat brochure, the Monsoon has a Monsoon logo (vs. a VW logo) screened onto the cassette door.
Are there any other ways to tell if it's a Monsoon system vs. non-Monsoon?
Thanks
Thanks
The head unit may, or may not be labeled. The headunit can be configured for either system via the VW diagnostic computer. The easy way is to look in the trunk for the Monsoon amplifier. On sedans, its bolted to the underside ofthe package tray.
Thanks...I looked under the package shelf...nothing there but metal framework for the shelf. I assume the amp would be a black box actually hanging below the metal?
Thanks again.
Thanks again.
Right. No Monsoon for you :)
I just learned this - that there's no difference between the HUs Monsoon versus non!.
Until I found this out I was baffled & confused why my radio manual has "Monsoon" all over it, the HU had nothing and I didn't have an amp.
-m
-m
The "System" is different, the HU is electrically the same. It is programed differently depending on application.
Maybe I ought to double check for my amp in the trunk... There is no Monsoon label on my HU, but when I turn it on "Monsoon" shows up in the LCD. I never checked for an amp, just assumed it was.
1 - 7 of 7 Posts
