1 - 8 of 8 Posts
what tools do i need and how long will it take?i need to send my tails to jonboy in the am tomarrow
thanks
cass
8mm socket (IIRC) and 5 minutes
It's a piece of cake, you'll figure it out.
If the B5s are similar to the B5.5s, all you'll need is a socket set (or a 8 or 10mm)- i think thats the size, a rachet, and it helps to have a socket driver as well.
Get a rag so you don't accidently drop the nuts down in the crevices of your trunk. It sucks to get them out, and if you don't have a magnectic wand, nows the time to get one.
The lights are straight forward, should be three nuts on each side. unscrew them all, then pull the wiring harness from the housing. viola!
all you need is a ratchet and sockets i think the socket size is either 10mm or 12mm not sure. each tailight has three screws each. to take out the driver side tailight open the first aid kit storage compartment remove the tailight bulb holders and locate the the screws. loosen and pull on the tailight. to take out the passenger side just remove the carpet covering the back of the tailight and repeat steps you did to take out the driver side tailight.
Same procedure for the Variant tails?
3 8mm sockets, should take 5 min, however i had a lot of problems with the left tail light's top nut, i couldn't get the socket in there.
since i had my sub installed a piece of plastic was already cut slightly, and i didn't have a smaller socket, so i snapped it off at the top, that way i could wiggle the socket into place. no one will ever know where i broke it, unless i show them :wink:
well, or they read this :cry:
1 - 8 of 8 Posts
