1 - 1 of 1 Posts
Well, I found the cause of the car not going into gear with the engine on - bad pilot bearing. The next question is how does one remove it and put a new one in? I know I need a bearing puller + Slide hammer. Is it required to take the flywheel off to do so/ is there any snap rings holding it in or something like that?
Also on a side note: any quick tips on replacement of drivers side motor mount? Found that It was leaking after jacking the engine up a little.
Thanks for the help!
1.8T Manual FWD 2003 Passat
1 - 1 of 1 Posts
