The answer to this one is in the owner's manual - and if I had an owner's manual, I'd look it up. Unfortunately my manual has been MIA for years. :banghead: I wonder if someone with a manual would look it up:
Following a battery swap, all settings were lost. The owners manual documents a procedure to activate the memory seat feature and set up the buttons with custom seat positions. The activation process was something like: move seat to the forward most position, tilt the back cushion fully forward and the seat cushion fully upward until you hear a beep. Now the memory seats are ready to use.
I tried doing that with the key in (position 2), key out, so far no luck.
What's the real procedure?
Thanks!
This only works when wearing a VW baseball cap too....
I wrote VW about a year ago and told them they should add in the following steps:
passanger seat fully reclined; 2-pac in cd changer; VW baseball cap with the bill facing halfway between the neck and right ear; three, lucious kisses to the VW insignia on the steering wheel
Just my .02......i did this AFTER the above steps and it worked flawlessly.
