Don't ask how it happened, and I am 98% sure I ejected the CD in there. The power was shut off and I must have been dreaming and inserted a CD and now the unit won't recognize the CD and eject it.
On computer CD units, there is a paper clip manual eject mechanism. Is there such a feature in the double DIN single disc unit? Nothing in the manual... :-(
Have you tried disconnecting the battery? My stereo goes through the motions when being plugged in for the first time, maybe this will eject it?
You could try removing the fuse for 60 seconds. It's located in the main fuse panel in the dash on driver's door side. I can't remember which fuse # it is, check your fuse card. I've had to remove this when my radio wouldn't turn on it. I'd do this first before unhooking your battery connection.
