How to fix vertical headlight adjustment w/ pictures
5246 Views 2 Replies 2 Participants Last post by  SteveO525
4
Like many of you, my headlight adjustment ball and socket disengaged. I read the posts here about this issue and thought I would try to fix the problem. Although my headlights were aftermarket, I did notice that the adjustment screws are marked as to up/down and right/left.
Bumper Auto part Tire Automotive tire Automotive exterior
Also, while turning the adjuster, I realized that the plastic ball did NOT rotate.
Auto part Tire Vehicle Automotive tire Automotive lighting
I thought to myself " I'm gonna glue that sucker!" I used Duco Cement.
Auto part
Here is the finished product.
Auto part Wire Vehicle Electrical wiring Car
I will let the glue setup overnight and reassemble tomorrow, but I think it will work.
Reactions: 2
1 - 3 of 3 Posts
Works great.
On a side note, although the Up/Down adjustments are the same from drivers to passengers headlights (CCW to raise), the Right/Left are not. Drivers side is CW to move right, passenger side is CCW to move right.
Reactions: 2
Thanks! I'll look closer at the assembly to see if that is the problem
Steve
1 - 3 of 3 Posts
