See that thing sticking out right in front of the washer fluid bottle? There's a hex nut that you stick an allen wrench in and adjust. Same on the other side
Not on US spec cars...not sure about Canadian cars. There should be no need to adjust side2side. If you do have an issue, either your bulb is not properly seated, or your housing is not mounted correctly. Side 2 side adjustment is available on Euro cars to allow adjustment depending on which side of the road they drive on.One more question about adjusting headlamp : is there an adjustment for horizontal aim ?
Oh..you didn't mention the Bi-Xenons. I don't have them so no clue, but i'll check my Bentley tonightI do have OEM HID with AFS on my 2009 B6, so there must be a way to adjust the horizontal Aim since there's a motor inside and they both move from lest to right about 8 to 18 degrees.
