1 - 7 of 7 Posts
??? What you talking bout Willis :???:
i know that the window part isnt broken cuz i can hear it goin up and down plus i know it goes up and down cuz i can push the window down and press the button and it will go up
Well the only thing that hold the window in the door are the two clamps that are attached to those plastic clips which are part of the regulator. Basically, with a Mk4, B5 or B5.5, if the window doesn't work, you need a new regulator.
Paul :thumbup:
That's assuming the fallen pin is the problem. It would suck to get the door apart to find out it IS the regulator. I'd rather be prepared for an expensive bill and find it's cheaper than the other way around. No to mention, if you take the door apart like in the link you posted you could very well break the plastic pieces on the regulator clamps. I know, that's EXACTLY how I broke mine.
Paul :thumbup:
1 - 7 of 7 Posts
