It can be done. The passengers side is WAY easy than the drivers side.
Removing the air the cleaner box, MAF and the accordion type tube will net you a good amount of space for your hands to get into.
Using a 3/8 drive with flex sockets (or flex joint and a socket) is the best for getting under the exhaust manifold.
Getting the 3 nuts off exhaust down pipe will be the most difficult.
Nothing has to be done with a/c system for removing the exhaust manifold.
Make sure you check the mounting pattern of the original exhaust manifold. There are 2 different types of exhaust manifolds that were used.
