I've seen far worse spark plugs. But, they're a little dirty, a little rusty, and the electrodes are obviously eroded. They're also 10,000 miles past the recommended replacement interval. Guess what you should do? (GRIN)
No point in going to the trouble of cleaning them, then regapping only to risk an occasional misfire at high load (WOT) conditions. The electrode erosion on all plugs appears normal for 60K of use.
You are not supposed to regap platinum (or iridium afaik) plugs. I believe the issue is that if you bend the electrode, you can cause the platinum coating to flake off.
There's more deposits than would be ideal, but no more than what I'd expect for being 50% past rated life.
Really, with a modern car in decent running order, you should never have to clean and re-gap prior to the end of a plug's rated life. If you do, something is wrong with your car.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Volkswagen Passat Forum
