1 - 2 of 2 Posts
I just bought clear sidemarkers from parts4euro.com and I havent the slightest clue as to install them and the only instructions that came with them are in german! I'm going to see now if i could work between the two front doors. I didn't have any trouble installing the clear corners, but i'll push my luck and try now, any help will be great!!
Use a small flat head screwdriver to pop it off.
Going from the rear of the car the screwdriver to wedge between the body and the light. In the middle of the sidemarker there is an indent to help you prie it off. It should pop off make sure when you unplug it not to let the wire fall inside the fender. When you install the new one you hook it into the fender from the driverside and then pop it on.
HTH
1 - 2 of 2 Posts
