Ok I pulled out the knob by accident, and when I push it back in the two spring things on the side come out and while the lights work, its loose and the knob slides out.
Whats the trick? :mad:
Rukas,
In order to get the light switch out, you had to turn the dial a little to the left to get those clickers to pull in. To put it back in, make sure the knob is still turned a little to the left (from off), put the switch back in the hole, and turn the know back to the right so the clickers engage after the switch is in the hole.
Look at it this way, at least you know how to put in a euroswitch now :) :thumbup:
Carl III
ckatkinson said:
Rukas,
Carl III
It's the opposite. The switch itself has to be pushed in and turned to the right slightly so the tabs are inset (turn it a few times while looking at the side of the switch first). Push it in with headlight ON icon at 12 o'clock and turn the knob left and it should click in.
Uh.. ok. What he said.
Carl III
