agreedshummer said:The power bleeder is a great tool! Turns a 3-person job into a 1-person job. Hardest part of doing a brake fluid flush w/ the power bleeder is getting the car on jack stands and removing the wheels.
so basically, my 20 psi's did not get all of the air bubbles out of my system when doing a complete flush of the system, and if there was no air in the system to begin with, im assuming it is still a closed system and the VW people who first bled my brakes didn't mess up, and i didn't add any air, by using the power bleeder, why would i want more pressure to blow air out of the system.DZeckhausen said:I've written up a brake bleeding proceedure on my web site that you may find helpful: http://www.zeckhausen.com/bleeding_brakes.htm
You'll notice that I use a pressure bleeder to augment the bleeding process but not to replace a second person. I have yet to see a 1-person bleeding system that I like. Here are some comments I've made on the various systems out there, including SpeedBleeders: http://www.bmwtips.com/tipsntricks/braketool/bleeder.htm
If your pedal seems reasonably firm and you are happy with the way it feels, then there's no need to go back in and bleed the car over again. The most important thing is that you've got the old moisture-saturated fluid out of there, so there's less chance of corrosion and you've raised the boiling point, so there's less chance of fluid fade.jeffsu350 said:so basically, my 20 psi's did not get all of the air bubbles out of my system when doing a complete flush of the system, and if there was no air in the system to begin with, im assuming it is still a closed system and the VW people who first bled my brakes didn't mess up, and i didn't add any air, by using the power bleeder, why would i want more pressure to blow air out of the system.
basically, is it worth my efforts to waste another bottle of fluid just to top off and bleed the calipers one more time with the brake petal, even thought everything seems just fine, the new fluid didn't seem to do much, for my street driven car, petal still feels like stock fluid is in there, but im happy to know that the old [email protected] with water is out.
