I have a 1999 Volkswagen Passat 1.8 l t aeb motor somebody used my car to jump their car hook the battery up backwards car starts but dies with no throttle response throwing code p1565 information I got was blown fuse bad relay open circuit I searched all the fuses on the panel in the door on the driver side located none what would be my next step . Relays or are there more fuses I'm not seeing. The panel that labels the fuses is missing went through one by one all good. Also there's a high pitch noise coming from the throttle body or throttle body position sensor or in that area it stays on for about 10 seconds and then shuts off
So far I have reset the ECU by disconnecting the battery and touching them together car still did the same thing one more question when they say open circuit exactly what do they mean
