Hello so i have passat 97 1.8 adr (non turbo) and i cant pass emissions test...
IDLE:
CO%:0,8 (0.5 max)
CO2:13,5
HC:150 (100 max)
02:1,32
Fast idle/rpm
CO%:0,6 (0.3 max)
CO2:14,00
HC:80
Lambda:1,021
I have already changed catalytic convertor, Lambda sensor, engine coolant temp sensor, spark plugs, air filter, tried with 2 different used coil packs (same sparkplug wires), oils.
And still i cant pass emissions, so can anyone help me? there is few problems with the car i think might relate to this problem: car shaking on idle a bit (rpm dropping and rising by 50-100), when flooring gas pedal on idle i get weird hesitation like it takes around 1sec before rpms start to rise. And exhaust is leaking a bit after catalytic convertor
(And sorry for my bad english)
IDLE:
CO%:0,8 (0.5 max)
CO2:13,5
HC:150 (100 max)
02:1,32
Fast idle/rpm
CO%:0,6 (0.3 max)
CO2:14,00
HC:80
Lambda:1,021
