1 - 3 of 3 Posts
I just got hyper white lights for my 05 passat. I got a set of headlights and fog lights. Does anyone know the easiest way to get under to the fog lights? Do i have to take off the whole splash gaurd? Whats the easiest?
If you're talking about the fog lights that are integrated into the lower grill, that piece pulls out.
There are tabs on each side; pry out carefully.
Start towards the middle of the car on the grill/trim around foglights.
They take a pretty good tug, but be careful.
After that, three philips head screws and the Tube comes out.
Back piece sort of twists off, but I think you have to push in too.
Wire pulls loose with a wiggle.
Bulb is held in place with a wire clip.
The replacement bulbs will have a half-moon notch, and a square notch.
Test them before you reassemble the tubes into the lower bumper.
1 - 3 of 3 Posts
