Please feel free to move, if need be.
I noticed today that my JL audio component speakers are only partially working. The tweeters on both passenger doors are not working. The woofers do. It doesn't matter what input I'm using, be it my ipod, fm or am.
I have done a quick look over to make sure the wiring on the tweeters on both doors are okay and not touching.
Any ideas?
Thanks a ton in advance!!!!
what is your complete setup? monsoon and JL components only?
Yes. Everything is factory except for the speakers.
I'm just trying to find points of failure for two tweeters on the passenger side. I can't really think of much...
either the connector(s) to the tweeters are bad, or the mosoon amp is going bad would be my guesses. I'd start by removing the door panels and checking connections; they can oxidize over time.
if the connectors squeeze the blades tightly, simply disconnecting and reconnecting them mulitple times could fix the problem.
