Could some of you guys with a B5.5 1.8T pop your hood and post the part number for the big intake hose from the intercooler to the throttle body? You can see the number without having to touch anything.
I think there are two versions of this hose - one that uses an o-ring at the intercooler (look for a metal retaining clip) - and one that uses a standard hose clamp (like the other end of the hose at the throttle body). I can only find one part number using www.elcats.ru -- 3B0-145-834-D. Please note if your p/n is for the o-ring or the hose clamp version.
Thanks in advance...
Discussion Starter #2
^^shameless bump... c'mon guys it takes two minutes to check. exercise is good for you. :)
sorry
4B0 145 838
99 AEB 1.8T
Jonathan
I didn't see that you wanted B5.5. Mine's just a B5. Looks like a big clamp around the TB.
Re: sorry
Thanks anyway! :) The TB end always has a big clamp - look at the other end... clamp or wire-clip?
The end that hooks into the IC looks exactly the same as the end that hooks at the TB. Both Screw clamps(whatever you call it)
Jonathan
