Hi All,
I just bought a new Garrett 717858-5010S turbo for my 2002 B5.5 130 tdi avf engine. The old one has been leaking oil into the intake system - it's working fine but the leak was beginning to trickle down the sump and collecting at the bottom. What's more I just had the engine completely rebuilt, new clutch and dmf, new tandem pump, new egr valve, new intercooler. So the turbo now has to be swapped. I was planning to do this myself however whilst shopping around I found the following info from one vendor:
717858-5010S Garrett turbochargers for Volkswagen Passat 1.9TDi 130bhp were replaced by 716215-0001 turbos, which was a Direct Service Replacement. However, 716215-0001 Garret turbos are no longer available, so to service these two part numbers it is necessary to use turbochargers from the 717858 range and preferably, the latest one 717858-0009, but to make a minor adjustment to the Delta angle, by rotating it 6° CLOCKWISE when looking at the compressor end. This changes the Delta angle from 96° to 90°.
This should ensure fitting to the car with no problems. All other details are the same.
This delta angle business seems more involved than the simple remove/replace I was hoping to do. No other vendor mentions this in their info, which seems strange. The firm I bought the turbo from did not state that any modifications were necessary. Anyone have a view on whether this is the case with this turbo?
Any help greatly appreciated.
Thanks
Elliot
Thanks
Elliot
