1 - 8 of 8 Posts
Hi
The PR codes doesnt give me any hjelp - as usual.
VAG doesnt want to help - as usual.
The car isnt worth buying the parts from VAG. They have already fooled out of the owner over 20 000 dollars in the past 5 years. And wanted to take 3000 dollars to fix this. Car is not worth that much even - its run near 500000 km.
So if any one would know the correct VAG part numbers or the replacement Galwin part numbers - Id be very grateful!!
Picture of the the front and the PR page (just in case).
J.M.
Thanks!
The model year is 2011 (2011 ->).
The VIN is: WVWZZZ3CZCE089877
VAG were going to change everything - bumper, reinforcements, what the radiator and condenser hangs on.
I will palstic weld what has cracked and change the two pieces missing.
But there are several different options for the fog light trims. And Galwin, who makes and sells the aftermarket trims here in EU - only have a picture of one of the kinds, installed on these cars.
Its either called Highline or Comfort. Both have two chrome lists.
The third option only has one chrome list - at least I can rule that one out.
The picture of your 2011 vehicle has the front of USA 2012 and higher B7 Passats, so try using the wording below do a search on ebay:
Front-Bumper-lower Cover-Grille-For-2012-2019-VW-Passat
Good luck,
Yes - its a B7.
But, is it with a Highline front
Or a Comfort front?
I have no clue.....
The type of fog light that I found on your url - didnt look correct.
I have no clue, I was just trying to help you, but you should send your pictures and ask that question to the numerous ebay vendors through ebay to get an answer.
Again, good luck,
1 - 8 of 8 Posts
