1 - 7 of 7 Posts
i think it is my tie rods. could be a control arm.
when i jack up the front end of the car and grab the front tire (either side), it feels like the wheel is jiggling loose on the hub. the lugs are tight.
i can see from both sides that the joint of the tie rod end is allowing about 2-4mm play. -and yes, the rubber boots cracked ages ago.
is this the tell-tale signs of worn tie rod ends?
another tie rod bites the dust(boot)
yeah, new tie rod ends are needed. i got some at Pep Boys, but they do not fit... I did spend a little time pulling on the controll arms. they seem fine with 100K+ miles, but all the bushings have small tears in them. i dont thinK the tears are a big deal, it probably just decreases the compliance of the suspension? whatchya think?
Re: another tie rod bites the dust(boot)
tears let dirt and dust enter the joint . . . . that wears down the joint and causes them to get screwed up.
Dave
1 - 7 of 7 Posts
