1 - 9 of 9 Posts
2003 passat gls sedan 1.8t has the inline 4 its the 20 valve Awm engine code have some questions abo
I'm just confused kinda man I guess to be honest I'm pretty sure it's setup for some type of circuit racing or something like that. My turbo always seems to stay running like everything had become flashed I'm not to mart on these turbos but I am leaning alot
It lost engine power while I was getting on a on ramp then would not turn over at all. It has been running hot well temp gauge sensor is reading fine. I also have to put coolant in it but don't see any leaks and don't leave any leaks at all. But seen a tad bit on the ground once not alot. I'm confused. It had iridium spark plugs I priced them wasn't expecting that so I'm guessing it's flashed or chiped.
It lost engine power while I was getting on a on ramp then would not turn over at all. It has been running hot well temp gauge sensor is reading fine. I also have to put coolant in it but don't see any leaks and don't leave any leaks at all. But seen a tad bit on the ground once I pulled over. I'm confused. It had iridium spark plugs I priced them wasn't expecting that so I'm guessing it's flashed or chiped.
Discussion Starter · #6 ·
What is your question ?
It's on adjustable coilovers as well gets up quick and goes I'm just really wanting to know where to start I have already done some work and it ran great even when I got it until this has happened, so now I'm stuck on keeping it from heating up and why it basically stalled but only lost engine power and had battery power left sounded like a pop noise but really couldn't be sure
So the engine spins over but will not start?
No fuel or
No Ignition or
No/low Compression.
Something is missing!
1 - 9 of 9 Posts
