1 - 13 of 13 Posts
Hi Gang,
I have done a search but only found out dated links on installing the chrome trim that cover the rear slider part of the front center arm rest.
I have ordered the piece from germany but need some installation tips.
Also has anyone eveyr added the black interior door trim to their cars?
I have a W8 and on the interior door frames you can see the paint, looks cheap to me.
Some of the earler Passats had black trim tht covered the paint, anyone added this trim and or know the part numbers.
Thanks again,
Steve
[/b]
Discussion Starter · #6 ·
Do you actually have to remove that inside cover to the armrest, I guess I am not sure what holds the cover in place. I don't have my trim piece yet maybe it will be more obvious when it gets here
The thing thats the hardest is pulling the sides of the plastic cover so that it comes off the track - once that happens, it slides right off. Just use your nails, it will give a bit. The chrome one, once you align it it on the track slides right in but you gotta give it a good push. That is the best under $20 mod!!!
1 - 13 of 13 Posts
