I have a b5 passat atw with motaza tune 550cc injectors, big maf, big turbo inlet, with f21 turbo. Had garage install it got car back and cuts out at highrpms and since i didnt do the work i dont have any idea where to begin. Im run stock fuel pump newer 2.0t coils new plugs and manual boost controller . Runs fine if not boosted but when you get into it cuts out like crazy. Wastegate set at 8psi and im not running n75. Before with the ko4 on it was running fine but after the swap the the car runs terrible . I just need some advice to where to begin . Thanks
