21 - 29 of 29 Posts
Discussion Starter #21
It's the standard checklist for any starting problem. An engine needs spark, fuel and compression. You can borrow a compression tester and most parts stores with a deposit.
bout to head to the parts store to rent one also while messing with the car this morning found that my fuel pressure regulator is leaking.
Discussion Starter #22
so cant find a compression tester to rent in my area they all seem to be rented out. what else can I try at this point
Fix the FPR, clear the codes and see how it runs.
Dry, cold or warm? Either way, 30psi is really low. I make sure the engine is warm, throttle open and do a wet test after the dry just to confirm.
Discussion Starter #26
just finished driving the car for like 20 mins so it was good and warm
Ok, that's a real issue. You can try a wet test to see if the rings are stuck but you might also have a bent or burnt valve.
You may be able to tell by putting air pressure into the cylinder and listening to where it comes out; intake, exhaust or oil fill.
21 - 29 of 29 Posts
