About a month ago I bought a 1999 Passat and it had 2 problems, the secondary air pump running continuously (which I will save for another thread), and my power locks. At first I believed the problem with the locks to be within the driver side door. There was a trick to getting it to lock. I either had to be inside it and lock using the door button, or lock it with the passenger side key slot or button. Keyfob does not work. I was told the batteries were dead. The key will not lock the door using the driver side key slot.
This was just an annoyance until I had time to really get in and determine the problem. But a week ago I went to start my car and the alarm went off, engine would not start. So I took the key out and tried again. Same deal, then I shut the door and locked myself in then tried the key and the engine started, hasn't happened since. That same night I noticed my dome light not working and my sunroof would not open. I then noticed that the anti theft led on the driver side door was flashing rapidly. I can hear a ticking under my carpet that ticks in unison with the flashes. Sometimes the flashes will go back to normal and if I catch it when it happens I can open my sunroof. I did my research and found that the CCM controls all of these components. So I found a DIY and pulled out the CCM box. Of course the floor was soggy from the drainage issue passats have. Opened it up and found the blue plug to have a bit of corrosion within the terminals, the terminals are numbered and the ones with the most corrosion were #2 and #15. The ticking noise sounds like a bomb and is coming straight from the blue plug. The board appeared to be fine. So my question is this, what is the ticking inside the plug? Am I better off replacing the board or should I start by replacing the blue plug?
Thanks to all that read.
