So on a recent scan, I came back w/ this code:
Here's where it gets murky: The specific wording in my aftermarket warranty states that coverage on the brake system includes "Master Cylinder, Power Brake Cylinder, Vacuum/Hydro Assist Booster..." VW calls it a "brake pump" according to the dealer service writer and so the warranty company is denying the claim since there is no mention of "brake pump" in the coverage.
My question is this: Is the "brake pump" the same as the vacuum assist booster as indicated in the fault code? Anyone w/ the Bently care to confirm the code wording from VAG Com against the factory code designation?
Hey Sharky - Since you're the resident tech - what's the official VW book designation for this and is it the same?
I had it at the stealership to look at my fading instrument cluster for possible replacement and asked them to look at this fault code. Of course they tell me that I need a new Brake Pump. No problem I think. This should be covered by my aftermarket warranty. Think again.17887 - Brake Boost Vacuum System: Mechanical Failure
P1479 - 008 - Implausible Signal
