2004 2.8 V6 B5.5, now a 2012 CC GT
Looks like some time in the past, clumsy tyre replacement has squashed a pipe near the forward jacking point (Drivers-Left hand) side. I followed it from the front left when arch to the rear left wheel arch (Vacuum leak pump line?) If it is, it could be why i get a "gas cap leak-small", once in a while!
Does anyone have an idea what it is?
It (i think) goes to near the throttle body. I'd love to pull the wheel liner, but i'm away with work in a couple of hours so thought i'd pitch in here for sage advice (as always!)
Thanks in advance.
there is a vac line to the leak detection pump which is located inside the driver-side rear wheel well, so that's probably it. If that is the one, you can cut away the crushed part and rejoin it with a piece of rubber hose.
The other lines on that side are all brake lines. examine those very well.
Thanks, I'll probably go for that when I get back. It's like a rigid plastic line rather than metal so like you say, probably the vacuum line. I'll pull the wheel liner just to be sure.
Thank you.
