1 - 3 of 3 Posts
This is an 06 VW Passat 2.0t with the following codes: P2293, P0442, and P0087
I was driving down the highway and lost power, its almost like the fuel is being restricted.
I limped home and have been doing research all weekend but I'm not sure what to look at first.
I have the P2293 Fuel Pressure Regulator Valve (N276) Mechanical Malfunction P2293 lower limit reached along with EVAP Emission Control SYs Small Leak P0442 Upper Limit Reached and a Fuel Rail/System Pressure Too Low P0087 Not a Plausible Signal.
I am sure these are all related but I am not sure what the root cause is or where to look first.
Any ideas would be appreciated.
Thanks
Discussion Starter · #2 ·
Update:
So today I went to the dealer and picked up a gas cap. This eliminated 2 of the 3 codes. The Only remaining code is the Fuel Pressure Regulator Valve (N276) Mechanical Malfunction P2293 Lower Limit Reached.
I have cleared the codes and this is the one that comes back.
Some of the power has returned but it still is hard to start and the throttle lags.
1 - 3 of 3 Posts
