my driver's side rear window fell a few months ago and i finally found some time to try to fix it. i essentially followed these instructions with new plastic dowels:
http://www.passatworld.com/forums/showthread.php?t=87363
an hour and a half later, i still get the new dowel in place! can't figure out what i'm doing wrong.
-i bought the replacement dowels from ECS
-i put the smaller one inside the larger one
-i tried to put the dowel in the window hole with the window up and off the plastic platform and i can't push the dowel assy through the hole
-i tried to seat the window in the platform first and then push the dowel through the access hole and i can't push it through that way either
no matter how hard i try, i can't get the dowel through the damn hole!
is there an easier way? is there a different part i should be using?
thanks in advance for any help!
