1 - 13 of 13 Posts
as the title reads how the hell do i get the haze off the headlights.everything loooks so shiny then you get to the headlights and its killing me please help!!!
Try a clay bar, or a really light car polish. I've heard they work.
Unless the haze is on the inside from fogging...
what is the wet sanding process?
You can get "wet" sand paper that is made to be used with water while you're sanding the surface - just dip the paper in water and sand, keeping it wet. Use a circular motion and gentle pressure. You can get wet sandpaper at auto parts or hardware stores.
a highly regarded vw tech said this stuff works well (pricey at $28 though, you can get it at Advance Auto).
http://www.crystalviewchemicals.com/index.htm
One thing that appears different (at least to me) with the other kit is that this crystalview kit has some kind of final sealant step.
Brake fluid?
1 - 13 of 13 Posts
