b6 passat 2.0 t 81k.....hi all i need some assistance, i was trying to take out my HPFP to check the condition of my cam follower... i had read a few posts watched some videos seemed easy enough right? anyway on none of the videos did i see a fuel line on the bottom left of the pump next to the other one(i did see on the video) anyway i had to take out not only the fuel line but the whole thing on the right sided one to try and get at the nut for the left sided line...anyway i couldnt get it out so i put back the torx bolts put back the fuel line on the right side(looking from the front) which was a pain trying to push and hold and turn the fuel connector, anyway , now it leaks ?? i thought i heard something drop and i did find a small silver colored washer, which i lost again after trying to put it back on the right side fuel line,, sorry for long winded hard to explain w/o pics, i assume it was from the top of the right sided connector where it goes into the fuel pump body, but the fuel seemed to be leaking from the left side(how does the left side one come off, it looks like the nut is on top on the pipe and a hole in the bottom?), i really didn't touch that as the nut on the top seems to be too thin to get a wrench around it? anyone know if this was the washer from the right side connection? any one have a drawing with part numbers? help!! i need to get it back together to get myself to work, thanks.
