Hey, I got a question about the HID upgrade.
Where did you guys put the power supply of the HID or the voltage converter under the hood?
My power supply got wiped after I did my suspension upgrade.
I brought it back to the store where I purchased it,
and they changed me a new one under the warranty.
However, the light goes off again 3 days after the re-installation.
Anyone has a good idea for locating those huge power suppliers for HID?
Do u guys suggestion to locate them inside the car?
or keeping them under the hood?
My friend told me that there isn't enough room under the hood,
so putting them inside the car behind the fire wall will be an only solution,
since it has killed me 3 set of HID already.
Anyone who can give me a hand? or a hint???
If you put it in the car, would'nt you have to run a high voltage line all the way back to the lights? I mounted mine directly behind the headlights, attached to the radiator support.
Thanks. I will try it and see if it will works.
I wish if I will get it mounted behind the headlight.
Thank you.
:bow: :bow: :bow:
