1 - 9 of 9 Posts
Looks like I have a leak at the head gasket to the coolant tube at the back of the engine...does anyone know where I am refering too...and if this might be covered by VW (100K warranty)??? :???:
Has anyone else had a coolant leak other than the radiator itself??
thanks for any input
It should be i had a coolant leak to my turbo but i was out of powertrain warranty but my VW dealer claimed it would be covered so i woudl think urs would be too. If they try to give u BS about it i'd question things!
Lisa Simpson
Do you mean the T fitting on the back of the 1.8t?
If so, I had that leak a while ago. You need about 3 orings and an hour. You drain the coolant, remove the coolant T, and replace the orings. It is a bit difficult to get the thing back in there without the orings dropping out, but it will go. If you have a friend with small hands, it is easier.
yes Alex, on the back, but not the T type on the top. It is the one below it. I am about to post a couple pix in 15 minutes, If you and anyone else can look and see how or why this is leaking at 65K miles. It is a slow leak, but enough to have me get G12 fluid and top off a quarter inch every few days.
I dont have a leak but definitely small hands ,
1.8Tabamoura services available.
Holding the orings , pulling the 173 , changing DRL bulbs ,adjusting headlights and everything where small hands can come "handy"
:lol: :lol: :lol: :lol:
1 - 9 of 9 Posts
