I'm a noob with an '02 1.8T. I just purchased a Euroswitch and want to use it to the full extent, so I plan on wiring the rear fog lamp. Reflexive's web site http://www.geocities.com/MotorCity/Factory/8609/Passat/rearfog.htm
has the following instructions with the pictures below:
The key difference between B5 and B5.5 Passats is that B5.5 Passats already have the socket and bulb for the rear fog/extra brake light -- it is the high-intensity filament of the bulb in the lower circle of each taillight. On North American Passats, this bulb is electrically bridged to the high-intensity filament of the top circle. To perform the mod, you must break the connection between top and bottom circles.
My question is what am I supposed to cut? The two bridges circled on the bulb side of the tail lamp, or is connection inside the channel. Any help would be most appreciated.
Thanks for the response, but I ended up screwing up anyway. :mad: I cut through the two "bridges" on the bulb side of the tail light (pic 1). Now I have no break lights, and when I turn the rear fog on, the turn signal comes on continuously. Guess it's time for a new tail light assembly. For the future, do I cut through the top bridge only, no bridges or what? I'm obviously confused. :???:
Oh no, you cut the wrong thing. You have to cut the wire that is in the channel not the ones over the channel. Maybe this picture will help.
http://www.fototime.com/ftweb/bin/ft.dll/detailfs?userid={BF1D760C-2CD5-4334-83CF-F036A9CC135D}&ndx=5&slideshow=0&AlbumId={26939B64-BE4E-4607-AFBC-0D7DD145037B}&GroupId=&screenheight=1024
Here are Gordy's instructions that I used. If you want to retain all of the brake lights and add the fog, gordy's directions are good, if you want to do the euro-spec way, then you will have to deviate from his directions.
http://www.fototime.com/ftweb/bin/ft.dll/home?userid={BF1D760C-2CD5-4334-83CF-F036A9CC135D}&inv=A5478BF10A584AF&albumid={26939B64-BE4E-4607-AFBC-0D7DD145037B}
http://www.clubb5.com/forums/viewtopic.php?t=28896
If your not good with electronics or soldering then I would recommend you get help from someone who is, as having your brake lights work properly is pretty important. If you were local I would help you do it.
GMcHale, you've been very helpful. Perhaps I'll take your suggestion and have someone with a little more electrical experience give me a hand, if I decide to do it at all. This was one of those quick weekend mods gone wrong!
