First of all check fuse and relay of A/C system. If you say that system is not making neither hot neither cold air, probably can be electric problem related to some fuse or relay. Regarding relay you need to check does it switch when you start A/C and try to swap it for other relay you have in box. Can be that you have same relay both for A/C and sound system,etc. Best thing is to run Vag-Com from someone in your area.
