1 - 3 of 3 Posts
I only toke a few mins but It won't fit in the corner spot right???? There is like a gap between the headlight and the corner itself. Could it fit owith the OEM setup???
vdblu said:
Hella Clear corner will fit with stock headlights.
Thanks I tried it last night and it was dark but it didn't go in as easy as my other fluted clear corners did there is like two clear rubber dots on the inside lip and it make a gap in between the stock headlights...I will work on it sat.
1 - 3 of 3 Posts
