The driver's side seat heating is not working. Passenger side works fine. Wondering if there might be an easy solution to this? I checked the fuse and it looks good. Wondering if there might be some sort of plug underneath the seat that may have gotten unplugged?
Ideas?
Have you checked the wiring harness under the seat?
How about swapping the driver- and passenger-side switches in the dash to see if it's a switch problem?
Those would be my first two considerations.
This has happened to me occasionally. Try setting the temp to 0 and then back to the desired setting. This has worked in the past for me. Not sure why, have not investigated further.
i have the same problem
HERE you may get some more info about my investigation.
The switch is probably fine, I checked mine...
If you go under the seat look out for the side air bag wires.... :eek:
I know that my problem is
1. cacked wire somwhere inside the seat
or
2. lose harness inside the seat.
i stopped working on it because dont know how to remove the seat upholstery (sp?) without destroing it.... :???:
