Thats it. Did search,nothing found. Driver window and rear left window stop working after the car sits in the sun and gets warmed up (Florida). When the car is cool the windows work fine. The windows can still be closed and opened with the key in the door lock method. Help!
Not the heat
Fixed it. It turns out that the main terminal plug behind the door panel was loose.
Makes sense. Plastics typically expand faster than metals.
You could have switch cars with the guy in Minnesota that had trouble with his window when it was cold!
