1 - 8 of 8 Posts
so i got my alternator fixed and everything would be just great if my headlights would work. the two amber lights only, (turn signal lights) come on when i turn the switch. if i click the brights to stay on nothing happens & when i just try to flash the brights the passanger outside headlight comes on while the drivers side inside lights comes on. also my horn isnt working. but my brake & hazard lights do. and at the moment i dont have the key to the car (which is a long story in itself) so if anyone can direct me to where id find and howd id check these relays i would be forever thankful.
Discussion Starter · #2 ·
pulled the relay...
i put a jumper wire between 6 -7 and the wipers came on. when i put a jumper between 5 - 8 i got nothing. any sugesstions on what to check next?
Did you check the bulbs and fuses? Very common for both low beams to go at once. The issue might be a bad load reduction relay as well...
well the headlights work... sort of
well once i got my key back and after i changed the load reduction relay the headlights came on. the passenger side is much dimmer than the drivers side though. what should i check?
Bad load reduction relay, or bad ignition switch. There are a couple of threads about this (with pictures). Check the search - hopefully it might help ya.
Headlights, turn signals, wipers, rear defrost, heater blower...these all go through the load reduction relay, which is tripped on by the ignition switch.
Check that the bulb is seated in the housing properly. If it isn't, the HL will look dimmer. If that's ok, then I would suspect a failing ground wire somewhere. Are the high beams ok? The low & high beam share their ground, so that could rule out that connection...
1 - 8 of 8 Posts
