2000 V6 Passat wagon: I just found out that my headlights only turn on when the switch is pulled out for fog lights And the key is in the on position. The high beams work as should once the headlights are activated. I’ve never changed anything in my electrical system, nor come across any odd situation like this. Allis as came from the factory.
I recently had major oil leaks fixed which ruined my alternator. The alternator was replaced and all was driving well. Lastly, I had left the key in the on position for the better part of a week which totally discharged the battery. I got it recharged overnight with my cheap Walmart charger which was an ok solution according to my local battery expert.
Any advice on what I can check? I’m pretty sure this is an irregular situation although functional. Thanks
