1 - 2 of 2 Posts
Over the summer, I purchased my 2005 1.8T sedan. I took it to the dealership for them to check something out on the motor, and while there I asked them to take a look at my passenger side headlight, as it would shake a bit, and seemed loose when in "D". To my surprise, the dealer replaced the headlight, something must have really been out of kilter (under warranty of course). However, I was over at my parents house several weeks later, and when I flipped on the lights on their garage door, I about jumped out of my seat. My side was level all the way across, but the passenger side headlight was WAY out of whack. I did a little adjustment myself (thanks to this forum's writeup), and was able to level it out a bit, but when I tried to fine tune it, I could not get it right. So, while at another dealership over the weekend, I asked them to do an adjustment for me. They came back and told me it was fine. It is not that bad, but how would they do that? Is there a tool they use to line it up? I have also heard that the passenger side light covers more area, so as to pick up things on the roadside. With my Jetta, I remember a level, even light line that converged on a single point many feet from the front of the car. When it was foggy out, this was very evident. With my Passat, not so much. Any suggestions on how I should move forward? Should I maybe take the time to go back to the original dealership for them to look at it? I would not mind paying to have it right, even.
Thanks forum.
Reflex1.8T
Punches Dubs. True Story
The driver's side headlight should NOT be "level all the way across". Starting at the left, your beam pattern (assuming projectors) should have a horizontal line going across that angles up at approx. 30 degrees midway across.
There are a number of threads here that ...oh hell.
http://www.danielsternlighting.com/tech/aim/aim.html
This is approximately what you should see. Is it?
1 - 2 of 2 Posts
