If I install either the Neuspeed or Autotech rear sway bar (I think each is a 28mm o.d.), by how much will ground clearance be reduced? Also, will installation of either of these rear sway bars prevent or complicate later installation of a new exhause system?
Thanks.
I don't remember there being much difference when seeing some of the FWD cars up on the lift.... it looked to fit close to the rear axle.... you should see the4motion cars! :shock:
In the center of the car there is no problem,the sway bar is up by the twist beam.
The ends of the bar hang down about 2" lower than the bottom bolt on the shock.
Not sure about the exhaust,I would have too look at it again.
