4th Gear (Wax on Wax off)
After lowering your car what is the *measured* ground clearance in inches measured from the front edge of the belly pan to the ground and at the lowest part of the belly pan to the ground?
Also indicate if the car is a 1.8T / V6 / 4Mo
I am looking at lowering and was wondering what everyone ended up with.
Stock mine is 6" at the front edge of the pan and just over 5" at the lowest part of it. It has a bit of a rake and is a 03 V6 4Mo.
Bleser said:
2003 1.8T
Eibach Pro-System
6.5" @ front of belly pan, 5.2" @ middle or "low point" of belly pan.
:thumbup:
Sheesh I am lower than that stock with a 03 v6 4M0
6" front of belly pan . 5" @ middle or "low point" of belly pan
With my H+R Sports,I was at 3.5" on the belly pan. I added Bilstein adjustables to raise it 3/4" and
level it off,it was heavily raked. I have to check the latest set up.
2000 Passat,1.8T,Tip.
